  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
rk2
rk2
How to create a new column in a data table from a list of column values using conditional statements?
I want to check values in two numeric columns within a data table. Now I have these two numeric columns' names in a list. I use a for loop to iterate through the list of these chosen numeric column names, then i want to check against a threshold value (say 100). Then I want to create a new column and put labels accordingly - either label "A" or "B" - depending on the given columns in the data table.
Let's say these are the two numeric columns:
numeric_col_1 = {100, 200, 250, 700}
numeric_col_2 = {200, 250, 500, 100}
And the threshold is 100.
Now the labeled columns pseudocode I want to implement is as follows:
labeled_col = (if numeric_col > 100, "A", "B");
So the labeled columns will now show:
labeled_col_1 = {"B", "A", "A", "A"};
labeled_col_2 = {"A", "A", "A", "B"};
Here is some example code:
concat_dt = datatable("concatenated");
new_val_list = {"num_col1", "num_col2"};
name_list = {"col1", "col2"};
stop = nitems(new_val_list); for (i = 1, i <=stop, i++, col_name = name_list[i] || "_Label_A_B"; show(col_name); concat_dt << New Column( col_name, Character, "Nominal", Formula( If( Column(concat_dt, new_val_list[i]) > 200, "A", "B" ) ) ) );
But the above code only shows empty columns even though they have been created with their respective column names in the data table.
Re: How to create a new column in a data table from a list of column values using conditional statements?
Use As Column() instead of Column()
concat_dt = datatable("concatenated");new_val_list = {"num_col1", "num_col2"};name_list = {"col1", "col2"};stop = nitems(new_val_list);
	show(col_name);
		Character,
		"Nominal",
		Formula( If( As Column(concat_dt, new_val_list[i]) > 200, "A", "B" ) )
However, I believe this is a better solution
concat_dt = Data Table( "concatenated" );
For Each( {col, i}, name_list,
	concat_dt << New Column( "num_" || col || "_Label_A_B" ,
		Character,
		"Nominal",
		Set Each Value( If( As Column( concat_dt, col ) > 200, "A", "B" ) )
	show(col_name);
		Character,
		"Nominal",
		Character,
		"Nominal",
