MarcP
/How to create a bar chart of the loadings of the first canonical variable from a LDA?
The output of a Linear Discriminant analysis is a graph with lines representing the strength/significance (loadings) of each of the covariates/variables.
I would like to create a pareto/bar chart showing the variables and their loadings. How do I get the data from the LDA results?
Re: /How to create a bar chart of the loadings of the first canonical variable from a LDA?
You should be able to produce a data table of your output by right clicking on the "discriminant scores" table then selecting "make into a data table." You should then be able to generate your plot from that table using the Pareto platform, or Graph Builder.
