lala
Level IX
How to copy the list of column contributions of a random forest using a script?
Thanks Experts!
dt = Open( "$SAMPLE_DATA/Diabetes.jmp" );
p= dt << Bootstrap Forest(
	Y( :Y ),
	X(
		:Age, :Gender, :BMI, :BP, :Total Cholesterol, :LDL, :HDL, :TCH,
		:LTG, :Glucose
	Validation( :Validation ),
	Minimum Splits Per Tree( 5 ),
	Portion Bootstrap( 1 ),
	Number Terms( 3 ),
	Number Trees( 25 ),
	Go
p_report = p << Report;
tb = p_report << XPath("//OutlineBox[text()='列贡献']//TableBox");
no work
lala
Level IX
回复: How to copy the list of column contributions of a random forest using a script?
Re: How to copy the list of column contributions of a random forest using a script?
Use Make Into Data table, take the source script from that and modify as needed
rpt = New Window("Diabetes - Bootstrap Forest of Y",
	Data Table("Diabetes") << Bootstrap Forest(
		Y(:Y),
		X(
			:Age, :Gender, :BMI, :BP, :Total Cholesterol, :LDL, :HDL, :TCH, :LTG,
			:Glucose
		Validation(:Validation),
		Method("Bootstrap Forest"),
		Column Contributions(1),
		Minimum Splits per Tree(5),
		Portion Bootstrap(1),
		Number Terms(3),
		Number Trees(25),
		Go
Wait(0);
rpt["Bootstrap Forest for Y", "Column Contributions", Table Box(1)] <<
Make Into Data Table;
rpt << Close Window;
View more...
dt = Open("$SAMPLE_DATA/Diabetes.jmp");
bsf = dt << Bootstrap Forest(
	Y(:Y),
	X(:Age, :Gender, :BMI, :BP, :Total Cholesterol, :LDL, :HDL, :TCH, :LTG, :Glucose),
	Minimum Splits Per Tree(5),
	Number Terms(3),
	Number Trees(25),
	Go
Wait(0);
dt_res = Report(bsf)[Outline Box("Bootstrap Forest for ?"), Outline Box("Column Contributions"), Table Box(1)] << Make Into Data Table(Invisible);
m = dt_res[0, 0];
Close(dt_res, no save);
// could also
m = Report(bsf)[Outline Box("Bootstrap Forest for ?"), Outline Box("Column Contributions"), Table Box(1)] << get;
If you just want the columns, you can build it from the resulting list or
m = Report(bsf)[Outline Box("Bootstrap Forest for ?"), Outline Box("Column Contributions"), Table Box(1), StringColBox("Term")] << Copy Column;
lala
Level IX
I still didn't succeed with my own actual data.
dt=Current Data Table();for(i=5,i<=ncol(dt),i++,if(Column(i)<<Get Name=="xx",Break()));ss=i+1;cNa=dt<<get column names;cNa=dt<<get column names;xF=As List(cNa[ss::ncol(dt)]);
rpt = New Window("Bootstrap Forest of Y",
	Y( Column( 3 ) ),
	X( Eval( xF ) ),
	Method( "Bootstrap Forest" ),
	Number Terms( 46 ),
	Number Trees( 100 ),
	Go
Wait(0);rpt["Bootstrap Forest for Y", "Column Contributions", Table Box(1)] <<Make Into Data Table;
lala
Level IX
I use the Chinese version of JMP, but it is feasible to run this code.
cNa=dt<<get column names;xF=As List(cNa[3::ncol(dt)]);
		Y(1),
		X(Eval( xF )),
		Number Terms(3),
		Number Trees(25),
		Go
Wait(0);
Notice a difference between our scripts?
View more...
I'm using different outline box name than you are as I'm using wild card ? on purpose to replace the column name
You could possibly skip the first outline box reference and it should still work.
