jenssjorslev
How to convert column value labels to values?
I'm new to the community (but have used JMP since version 1), so I don't know where to put this question.
Have imported a file from SPSS (.sav) with several columns with value labels. I want to use the value labels (which are actual names) instead of the values (which are numbers). Recode seems not to have this function. Could anybody help? Thanks a lot in advance. Jens
10 REPLIES 10
jenssjorslev
Re: How to convert column value labels to values?
Thanks to all who has helped with this. Been away from the computer for some time, but now back to working with JMP. I'll try the different suggestions and see which is the fastest for me.
