zetaVagabond1
How to convert UTC timestamp to local time in a column formula
Hi all,
I have a column Timestamp UTC in JMP with values like 2025-10-31T08:30:00.
I want to create a new column Timestamp Local that converts this UTC time to local time
Is there a simple formula-based way to add 5.5 hours to my timestamp directly in a column formula, without scripting or using Date Add?
Something like:
Informat(:Timestamp UTC, "yyyy-mm-ddThh:mm:ss") + (4 * 3600)
 but I’m not sure if this is the right syntax as it doesn't yield result nor formula evaluation errors
I also tried based on a discussion thread:
Informat(:Timestamp UTC, "Format Pattern", "<YYYY><-><MM><-><DD><'T'><hh24><::><mm><::><ss>Z") + (4 * 3600)
- No result
The Formula looks like:
Also tried Format - "yyyy-mm-ddThh:mm:ss"
col_name_list = Current Data Table() << get column names( string );
If(
	!Contains(col_name_list, "Timestamp Local"),
	Current Data Table() << New Column(
		"Timestamp Local",
		Numeric,
		Continuous,
		Format("m/d/y h:m:s"),
		Formula(
			Informat(:Name("Timestamp UTC"),
			//"Format Pattern",
			"yyyy-mm-ddThh:mm:ss") + (4* 3600)
Would appreciate any guidance or examples on how to handle UTC to local conversions cleanly within column formulas.
10 REPLIES 10
mlo1
Re: How to convert UTC timestamp to local time in a column formula
Is this an option?
New Column( "Time Plus",
Numeric,
"Continuous",
Format( "yyyy-mm-ddThh:mm:ss", 19, 0 ),
Input Format( "yyyy-mm-ddThh:mm:ss", 0 ),
Formula( :Timestamp + In Hours( 5.5 ) ),
Set Selected
zetaVagabond1
I should have added this for reference.
Since, this is from raw data - modeling ttype - continuous
Format defined  as:
I tried the formula above, it didn't yeild any output. I will check again.
New Table( "Untitled",
	Add Rows( 2 ),
	New Column( "old", Character, "Nominal", Set Values( {"2025-10-31T08:30:00", "2025-10-31T08:30:01"} ), Set Display Width( 153 ) ),
	New Column( "new",
		Numeric,
		"Continuous",
		Format( "Monddyyyy h:m:s", 22, 0 ),
		Input Format( "Monddyyyy h:m:s", 0 ),
		Formula( Informat( :old, "yyyy-mm-ddThh:mm:ss" ) + In Hours( 5.5 ) )
JMP stores date-time values as numeric seconds since 1904. The InHours function returns 3600 * the argument. I'm assuming you've got character data in the Timestamp column (old, in my example.)
zetaVagabond1
Format defined  as:
zetaVagabond1
However, this formula doesn't work
If(!Contains(col_name_list, "Max Timestamp UTC"),
		"Max Timestamp UTC",
		Numeric,
		Continuous,
		Format("m/d/y h:m:s", 22, 0),
		Formula(
			Col Maximum(
				/*Informat(
					Substitute(:Name("Timestamp UTC"), "+00:00", ""),
					"yyyy-mm-dd hh:mm:ss"
				:Name("ID")
The as is version, commented part of the code seems to take longer goes into an infinite loop as it causes my JMP to not respond and I have to kill the application.
I have done this earlier but local time stamp is generated  without using below code.
:Name("Timestamp UTC") << Data Type(Character) << Modeling Type(Nominal);
Which JMP version are you using? If you are having some issues with the speed with Col Max I would first create separate column with
Informat(Substitute(:"Timestamp UTC"n, "+00:00", ""), "yyyy-mm-dd hh:mm:ss")
and then use that newly created column as by variable.
zetaVagabond1
Yes, I had tried that
dt:Name( "Timestamp UTC" ) << Informat(
	Substitute( :Timestamp UTC, "+00:00", "" ),
dt:Name( "Timestamp UTC" ) << Data Type( Character ) << Modeling Type( Nominal );
col_name_list = Current Data Table() << get column names ( string );
If( !Contains(col_name_list, "Timestamp UTC (Numeric)"),
    "Timestamp UTC (Numeric)",
    Numeric,
    "Continuous",
    Formula(
        Informat( Substitute(:Timestamp UTC, "+00:00", ""), "yyyy-mm-dd hh:mm:ss" )
dt:Name("Timestamp UTC (Numeric)") << Delete Formula;
dt:Name("Timestamp UTC") <<
	Set Values(:Name("Timestamp UTC (Numeric)")) <<
	Data Type(Numeric) <<
	Format("m/d/y h:m:s", 22, 0);
I am trying this. It's overwriting my timestamp utc column and no values
Can you provide example of the table you are using? Just the timestamp columns should be enough (also remember to drop table variables/scripts).
zetaVagabond1
@mlo1 @Craige_Hales
This has worked.
If( !Contains( col_name_list, "Timestamp Local" ),      //If the column name doesn't exist in the array col_name_list
	"Timestamp Local",
	Numeric,
	"Continuous",
	Format( "m/d/y h:m:s", 22, 0),
	//Input Format( "Monddyyyy h:m:s", 0  ),
	Formula(
	//In Format( :Timestamp UTC, "yyyy-mm-ddThh:mm:ss" ) + In Hours( 5.5 )
	Informat( Substitute(:Timestamp UTC, "+00:00", ""), "yyyy-mm-dd hh:mm:ss" ) + In Hours(5.5)
	//Formula( :Timestamp + In Hours( 5.5 ) ),
	//Set Selected
TIme UTC
Time Local
2025-09-14 07:51:52+00:00  09/14/2025 1:21:52 PM
2025-09-14 07:56:52+00:00 09/14/2025 1:26:52 PM
