There are quite a few options depending on your application, below are few:
Easiest option would most likely be to use Data Filter
![jthi_0-1678135176124.png jthi_0-1678135176124.png](https://community.jmp.com/t5/image/serverpage/image-id/50769iAFB5A356CE6FFD8F/image-size/medium?v=v2&px=400)
Other option could be to use << Set Function which you could script to Hide and Exclude correct rows in your data table
Summarize(dt, uniq_names = by(:Name));
nw = New Window("",
h list box(
Check Box(
uniq_names,
<< Set Function(function({this},
sel_names = (this << get selected);
// row state 6 is hide and exclude
rows_to_hide = dt << Get Rows Where(Contains(sel_names, :name));
m = J(1, NRows(dt), 6);
m[rows_to_hide] = 0;
dt << Set Row States(m);
gb = Graph Builder(
Size(528, 456),
Show Control Panel(0),
Variables(X(:weight), Y(:height)),
Elements(Points(X, Y, Legend(5)), Smoother(X, Y, Legend(6)))
