natalie_
How to combine multiple data tables and plots into one report?
Hi Everyone,
I have three scripts which create three different data tables and multiple plots.  What I want to do is create one large report.  I see how to combine all the plots into one report/window and I see how to combine the data tables into one report/window.  Is there a two combine the two windows/reports?
ms
Super User (Alumni) ms
Re: How to combine multiple data tables and plots into one report?
One way is to append the reports to a horizontal list box:
biv1 = Bivariate(Y(:weight), X(:height));
biv2 = Bivariate(Y(:age), X(:height));
New Window("Example", hlb = H List Box());
hlb << append(Report(biv1)) << append(Report(biv2));
You can also explore the power of the SheetBox() or "SheetPanelBox" display box types that allow for custom arrangement of other display boxes horizontally and/or vertically.
natalie_
Hi again,
So I combined the scripts to make one data table, and I used new window and append functions to add all the plots to one report.  They are all plotted below each other.  Is there a way to plot some horizontally?
ms
natalie_
Thank you, it is very simple to arrange the plots on the report!
Peter_Bartell
Level VIII
natalie:Perhaps an opportunity for using Application Builder?
natalie_
Hi Peter, I would like to start using the application builder soon, too.  I am just not sure how to do it yet.
Peter_Bartell
Level VIII
natalie: Here's some resources on jmp.com that can get you started with Application Builder...tutorials, white papers, videos, etc.:
Analytical Application Development | JMP
natalie_
Thank you, I will check it out
