tajrida
How to color continuous data histogram based on category data?
I have two(2) columns:
1. First column contains continuous data on turn around times.
2. Second column contains categorical data (types of departments) eg: microbiology, histology, chemistry etc.
when I create a histogram distribution of turn around time data and use local data filter to filter out departments: I would like to see a different color histogram for different color department.
Right now all departments show the default histogram color. I tried using "color or mark by column" feature but apparently this feature does not work for histograms
Mohammed Ahmed
louv
Staff (Retired)
Re: How to color continuous data histogram based on category data?
One color for each sex (Blue=F, Pink=M, and Purple=Both M&F). The third color to show the overlap.
The histograms are presented separately below
louv
Staff (Retired)
Would this Graph Builder output work?
tajrida
LouV,
I think we are half way there. I do need to present these histograms separately for each category. In your case there will be a separate chart for male and female.
BTW: why do you have three(3) different colors for two(2) levels of sex?
Thanks for your help!
Mohammed Ahmed
louv
Staff (Retired)
tajrida
Perfect Thanks!!
Mohammed Ahmed
louv
Staff (Retired)
