yu629xiao
How to collapse Journal with JSL script
Hi , I am wondering how to collapse Journal with JSL script . when I finish one JSL script with jrn1<< Journal ended, which comment can be continued after to collapse all my Jrn1 graphic ? I try below but fail
Jr1 = " ................";
Jrn1 << Journal;
Jrn1 << Close all like This;
thanks
Re: How to collapse Journal with JSL script
A Journal is an Operating System window, unless you are referring to a Journal Box(), which is part of a window.  A window is normally Minimized to move it out of the viewing area.  Now, objects within a Journal, in particular, Outline Box()s can be collapsed, or the visibility setting can make them disappear.
See the Scripting index on Windows and Outline boxes.
yu629xiao
Thank you sir, actually I mean to collapse the Objects in Journal. after "... <<Journal " script finishing. Currently every time once I finish this script, new Journal windows pop out and all object was expended. Then I have to click "Ctrl+ top left triangle" to collapse all objects.   I do not want to click this every time after script finishing. so what's the script post "<<Journal " ?
This should do the trick
current journal()[OutlineBox(1)] << close all like this;
yu629xiao
Awesome! it works as I want. thank you
