Hi @JZ,
Welcome in the Community !
In order to solve this problem, you can try to add in your "Group" column a "Value Order" property.
To do this, right-click in your "Group" column name, click on "Column Properties" and then "Value Order" :
You can then in the new window indicate the order of the categories :
And this ordering will be kept in the graph builder :
Victor GUILLER
