RahBarroso
How to change interval lines on Plot Col Boxes
I’m trying to create a table box report from student t-test results that I can use for a report. When you run a students t-test in the Fit Y by X platform, each run has a Plot Col Box that shows the difference, lower and upper CL as a range, which is coloured by whether the CL’s cross the reference line of 0 difference.
The challenge I’m having is when I try to recreate this and bring in a Plot Col Box, when I add a reference line, the points turn red, regardless of whether they have crossed the CL (See the same data below, plotted in my tablebox).
I have found ‘set interval line properties’ in the Scripting Index but there is no guide for how to use it, you can see in the attached script I have tried to use it to set the properties to match those found in the Fit Y by X report, but no change happens, and the reported values change away from the values I have set them to. The Plot Col Box has options to change the bar colour when the plot type is set to bars, but I don’t see any easy way to change intervals.
Any clarification would be appreciated!
Thanks!
Re: How to change interval lines on Plot Col Boxes
Maybe this example provides some help
New Window("Example",
	Table Box(pcb = Plot Col Box("Probability", {25, 45}))
pcb << Set Plot Style("Interval");
pcb << Set Scale(0, 55);
pcb << Lower([10, 20]);
pcb << Upper([30, 50]);
pcb << Set Reference Line(11);
pcb << Set primary interval line properties("Red", "Red", "Green");
