kaushik_pushpen
How to call multiple text file to extract data in a single data table?
I have extracted the useful data from one text file into a new data table using JMP script. But, how to extract data from 3-4 text file using script into a same new data table? Please suggest me.
Re: How to call multiple text file to extract data in a single data table?
If you used File->Open->TextFile to import a CSV, for example, there should be a script in the imported file that you can use/modify to import another file.
You can use JMP's Table->Concatenate to combine tables.
aa = Open( "C:\Users\User\Desktop\a.csv" );
bb = Open( "C:\Users\User\Desktop\b.csv" );
cc = aa << Concatenate( bb );
Close( aa, "nosave" );
Close( bb, "nosave" );
kaushik_pushpen
Hello Craige,
Thanks for the previous answer.
I am running the following variability script, but it is not showing the result. Please check the code.
dt1 = open("C:\Users\llenovo\Desktop\RAW1.jmp");
dt2 = open("C:\Users\llenovo\Desktop\Parameters.jmp");
dt3 = dt1<<summary(group(ParameterId, USL, LSL));
for(i=1, i<=2, i++,
  for(k = 2, k<=nrow(dt3), k++,
         if(:column(dt2, 1)) == column(dt3, 1),
         usl = column(dt3, 2);
         lsl = column(dt3, 3);
dt1 << Variability Chart(
  Y( :MeasuredValue ),
  X( :EntryDate, :LotID, :WaferNo ),
  Analysis Type( Name( "Choose best analysis (EMS REML Bayesian)" ) ),
  Std Dev Chart( 0 ),
  where(:ParameterId == Eval((char(column(dt2, 1))))),
  Dispatch(
  {"Variability Chart for MeasuredValue"},
  NomAxisBox,
  Rotated Tick Labels( 1 )
  Dispatch(
  NomAxisBox( 2 ),
  Dispatch(
  NomAxisBox( 3 ),
  Dispatch(
  "2",
   ScaleBox,
   {Min( 10 ), Max( 500 ), Inc( 50 ),Minor Ticks( 2 ),
   Add Ref Line( usl, Solid, {255, 0, 0}, "lsllabel" ),
   Add Ref Line( lsl, Solid, {255, 0, 0}, "usllabel" ), Show Major Grid( 1 ),
   Show Minor Grid( 1 )}
Always check the log window for messages.
Add
Show(lsl, usl, i);
after the two nested for-loops and make sure the values make sense.  I'm pretty sure "i" will be 3 and that might not make sense when used in the where statement.  Does dt2 have at least 3 rows?
If that doesn't help, and no one else chimes in, call Tech Support.  I'm out of my depth on the variability platform.
