How to calculate linear-Log trapezoidal method (lin up /log down) in JMP?
Hi!!
I have previously been calculating the trapezoidal equation from my data without any issue in JMP but I need to run this time a Linear-Log trapezoidal method (lin up /log down).
Can somebody give me a hand with the script or equation I should include for such type of analysis?
Thanks in advance.
Best,
Marlly
ian_jmp
Level X
Re: How to calculate linear-Log trapezoidal method (lin up /log down) in JMP?
I'm sorry, but I'm not familiar with the method you mention, but I think this is it. Do you have any data that you might share? You could use the Tables > Anonymize' option if it helps.
Hi Ian,
Thanks a lot for your reply. Indeed, I have seen that explanation in Certara and other sites but non in SAS. Also, it is still not clear to me how to apply the equation. I sens you here the anonymized table.
Thanks!
Marlly
