HubP_SDe
How to use Variables for Custom Quantiles
Dear Community,
I've been struggling for a while now, looking for a way of replacing the hardcoded values 0.95 and 0.99 below, with variables in an Application.
	Continuous Distribution(
		Column( Eval( colSelect ) ),
		Horizontal Layout( 0 ),
		Histogram( 0 ),
		Vertical( 0 ),
		Std Error Bars( 1 ),
		Count Axis( 1 ),
		Show Percents( 1 ),
		Show Counts( 1 ),
		Axes on Left( 1 ),
		Outlier Box Plot( 0 ),
		Set Bin Width( 1 ),
		Custom Quantiles( 0.95, [0.95, 0.99] ),
//		Custom Quantiles( ( Eval( Percent1 ) /100 ), [( Eval( Percent1 ) /100 ), ( Eval( Percent2 ) /100 )] ),		Customize Summary Statistics(
			Std Err Mean( 0 ),
			Upper Mean Confidence Interval( 0 ),
			Lower Mean Confidence Interval( 0 ),
			Minimum( 1 ),
			Maximum( 1 )
This Dialog script comes with a set of custom variables, including the column to be analyzed ("colSelect"), and two Percentile values, that are all well retrieved (Show(), earlier in same script):
dt = DataTable("Dep0Times_Overall_IST5000");
colSelect = "Total Time From Entrance Queue To First Pre-Sortation";
Percent1 = 95; Percent2 = 99;
Whether I try the red line above with or without the Eval() method, I get the same annoying error below:
Invalid matrix token.
Line 50 Column 49: ...val( Percent1 ) /100 ), [►( Eval( Percent1 ) /100 )...
Thanks!
Stéphane DELACROIX
Senior Simulation & Planning Engineer
HubP_SDe
Re: How to use Variables for Custom Quantiles
Jim & all,
This finally works (maybe not the most elegant syntax)
Percent1 = 95;
Percent2 = 99;
percentMatrix = Matrix( {{ Percent1 /100 }, { Percent2 /100 }} );
percentMatrix = [0.95, 0.99];
Custom Quantiles( ( Percent1 /100 ), percentMatrix ),
instead of:
percentMatrix = Matrix( Percent1 /100 ) || Matrix( Percent2 /100 );
percentMatrix = [0.95 0.99]
Cheers!
Stéphane DELACROIX
The percent values are elements in a matrix, if you create the matrix before the Distribution, then it is a simple substitution to have it used.
dt = open("$SAMPLE_DATA/big class.jmp");
colSelect = "height";
percent1 = .95;
percent2 = .99;
perMatrix = Matrix( percent1 ) || Matrix( percent2 );
distribution(
		Histogram( 0 ),
		Vertical( 0 ),
		Count Axis( 1 ),
		Show Percents( 1 ),
		Show Counts( 1 ),
		Axes on Left( 1 ),
		Set Bin Width( 1 ),
		Custom Quantiles( Percent1, perMatrix ),
		Std Err Mean( 0 ),
		Minimum( 1 ),
		Maximum( 1 )
HubP_SDe
Jim & all,
Percent1 = 95;
Percent2 = 99;
instead of:
Cheers!
Stéphane DELACROIX
