PhamBao
How to calculate UCL from Mahalanobis Distance
Hi all,
Currently, I am using JMP 12 version
Do you know how to calculate UCL distance from Mahalanobis Distance chart?
If you guy know how to get it, could you please show me the formula?
Sincerely
11 REPLIES 11
Re: How to calculate UCL from Mahalanobis Distance
I believe you are misusing the outlier analysis. It applies to linear correlations. You have a non-linear relationship between two variables. I would not expect it to correctly identify outliers and non-outliers in such a case.
PhamBao
Hi Mark
Appreciate for your input. You are correct. Both variables are non-linear. Which method can I use to detect outliers from non-linear variables.
Sincerely,
