markw
How to calculate TF-IDF
Dear all,
I am new to using this software and am struggling to figure out how to use it to calculate the TF-IDF values for documents in my data set.
I am sure it is included in the functionality of JMP but it must be under a different name. Would anyone be able to point me in the right direction?
Thanks
Mark
11 REPLIES 11
Georg
Re: How to calculate TF-IDF
you may have a look at text explorer (main menu analyse),
please see the following example as script, or in scripting index, or in statistics index (main menu help).
dt = Open( "$SAMPLE_DATA/Consumer Preferences.jmp" );
obj = dt << Text Explorer( TextColumns( :Reasons Not to Floss ) );
Georg
markw
Thank you for your reply Georg. Please note I am a complete beginner so in need of a very basic explanation...
In practice I have a set of x documents, for 2 of which I would like to calculate the TF-IDF.
When I go to text explorer, can I get JMP to calculate the TF-IDF through using menu options and how do I specify for which documents I would like the TF-IDF to be calculated?
mlo1
View more...
Hello
did you check out the "Local data Filter" to chose the documents you want.
Georg
My way would be to get the text first imported into a table (JMP can Import even full Folders via multiple file Import …),
and then using text Explorer on that data table.
So this depends on type and structure of your files.
Georg
mlo1
May be it is worth to check out the following AddIn as well Text Importer - Text, PDF, Word Documents, and Powerpoint
The TD-IDF is one of the built-in transforms that may be applied to the document-term matrix when you save it back to the data table from the Text Explorer platform.
P_Bartell
Level VIII
Have you looked at the JMP documentation, Text Explorer section? Here's a link: Text Explorer
Much will depend on how your curate your documents...so pay attention to that first before any analytics.
Martin1407
Hi Mark,
I've got the same issue. Need to solve this as part as an Assignment for my Degree. Did you find a solution?
Best,
Martin
markw
Thanks everyone for your help, with your collective help I have managed to find the solution:
Under text explorer, go on save document term matrix and the option for TF-IDF is found under weighting.
