lala
Level IX
How to automatically combine this complex conversion?
In JSL, there is already a list variable abc. How can the values of this variable be written one by one into a new script without automatically re-entering the specific variable values
abc={"A","B","C","D","E"};
dt=New Table("A",Add Rows(1),New Column("A",Character,"Nominal"));
Eval(Parse("dt<<new script(\!"SS\!", abc; );"));
Eval(Parse("dt<<new script(\!"OK\!", abc={\!"A\!",\!"B\!",\!"C\!",\!"D\!",\!"E\!"};; );"));
Re: How to automatically combine this complex conversion?
Is this what you are looking for?
abc = {"A", "B", "C", "D", "E"};
dt = New Table("A", Add Rows(1), New Column("A", Character, "Nominal"));
Eval(EvalExpr(
	dt << New Script("A",
		Expr(abc)
Or do you wish to have a script which will set abc variable to the list of values within the table script?
mmarchandFSLR
The JSL Quote() required for the Event Handler makes things more difficult.  I'm not sure there's another way than to Parse() it.
dt = New Table( "A", Add Rows( 1 ), New Column( "A", Character, "Nominal" ) );
xx = 1.3;
Eval(
	Parse(
		"\[:A << Add Column Properties(
	Set Property(
		"Event Handler",
		Event Handler(
			Click(JSL Quote(Function( {thisTable, thisColumn, iRow}, {},
dt=Current Data Table();
abc=]\"
		 || Char( xx ) || ";
9 REPLIES 9
Eval(EvalExpr(
		Expr(abc)
lala
Level IX
OK
Eval(EvalExpr(
		abc=Expr(abc)
You generally have three options
// No variable
Eval(EvalExpr(
	dt << New Script("A1",
		Expr(abc)
// Freely define the variable name within table script
Eval(EvalExpr(
	dt << New Script("A2",
		abc = Expr(abc)
// Use expression to define variable and it's value within table script
// If you need abc defined outside of table script, you can use Eval(abc_expr);
abc_expr = Expr(abc = {"A", "B", "C", "D", "E"});
Eval(EvalExpr(
	dt << New Script("A3",
		Expr(Name Expr(abc_expr))
lala
Level IX
How can do it
Thanks Experts!
xx=1.3;
:A<<Add Column Properties(Set Property("Event Handler",Event Handler(Click(JSL Quote(Function( {thisTable, thisColumn, iRow}, {},
abc=Expr(char(xx));
lala
Level IX
I want get:
abc=1.3;
mmarchandFSLR
xx = 1.3;
Eval(
	Parse(
	Set Property(
		"Event Handler",
		Event Handler(
abc=]\"
		 || Char( xx ) || ";
lala
Level IX
Thanks Experts!
However, the event response link in column B was not created successfully
dt = New Table( "A", Add Rows( 1 ), New Column( "A", Character, "Nominal" ), New Column( "B", Character, "Nominal" ), New Column( "C", Character, "Nominal" ), New Column( "D", Character, "Nominal" ) );
xx = 1.3;yy="two";
Eval(Parse("\[:A << Add Column Properties(Set Property("Event Handler",Event Handler(Click(JSL Quote(Function( {thisTable, thisColumn, iRow}, {},
abc=]\"
|| Char( xx ) ||
Eval(Parse("\[:B<< Add Column Properties(Set Property("Event Handler",Event Handler(Click(JSL Quote(Function( {thisTable, thisColumn, iRow}, {},
dt=Current Data Table();dt[1,"A"]="one"
dt[1,"C"]=]\"|| yy || "\[;
dt[1,"D"]="th"
It does give you error message
Unexpected "dt". Perhaps there is a missing "," or ")".
Trying to parse arguments of function "Function".
Line 3 Column 1: ►dt[1,"C"]=two;
Indicating that something is most likely wrong with the syntax. In this case it seems like you are missing ";" after "one"
lala
Level IX
dt=Current Data Table();dt[1,"A"]="one";
dt[1,"C"]="]\"|| yy || "\[";
dt[1,"D"]="th"
