Dib-Dey
How to auto-run attached scripts on a table pulled from database
Following code will attach all jsl scripts in c:\work directory to the table dt.
Do you know any function/command which can also make it auto-run on the table?
dir = "C:\work";
fileNames = Files In Directory( dir );
if (dir!="",
	For( iFile = 1, iFile <= N Items( fileNames ), iFile++,
			filename = fileNames[iFile];
			show(filename);
			If( Ends With( filename, ".jsl" ),
				file_path = dir || "\" || filename;
				show(file_path);
				x = Load Text File( file_path );
				Eval( Parse( "dt << new script(filename," || x || ")" ) );
Re: How to auto-run attached scripts on a table pulled from database
The
dt << run scripts( filename );
will run the script after it has been saved to the data table.
dir = "C:\work";
if (dir!="",
			show(filename);
				show(file_path);
If you want all of the scripts run whenever the data table is opened, you can add a table script called OnOpen where you could specify to run each of the table scripts.
