natalie_
Level V
How to apply a formula to an existing column with a variable name?
Hi all,
I would like to apply the same formula to multiple existing columns in my data table using JSL.
I have one column that says 0V and the other that says RP_0V.  I would like to apply a formula to column RP_0V using the 0V column.  I have to do this many times (for column RP_10V using the column 10V, etc.)
I am having a lot of trouble figuring out the syntax for it, and I bet it is pretty simple...
for(i=0, i<=65, i++,
  colName =Column(char(i*10)||"V");
  dtSummary:("RP_"||char(i*10)||"V") = Formula(100*Col Rank(:colName)/1006);
natalie_
Level V
Re: How to apply a formula to an existing column with a variable name?
I got it to work!  My main problem was that I wasn't using ​AsColumn​.
for(i=0, i<=0, i++,
  colRP=("RP_"||char(i*10)||"V");
  Column(colRP) <<Formula((100*Col Rank(:AsColumn(colName))/(1006)));
natalie_
Level V
for(i=0, i<=0, i++,
