pavanroast
How to add the date to file name while uploading a file to s3 bucket using alteryx
I have a workflow in alteryx where I am downloading two files from two different urls. After making the required modifications I want to upload them to the s3 bucket as well as save a copy locally. I want to add the current date while saving the file in both cases. I was successful in using a formula tool to rename the file saved locally. But unable to do for the copy being uploaded to s3. Can anyone help me with this? PS: Since it's the company data I cant share the screenshot of the workflow.
Re: How to add the date to file name while uploading a file to s3 bucket using alteryx
Are you using JSL?(Sorry, I'm unfamiliar with alteryx and s3.)
Can you print the the name to the JMP log just before you upload it? I'm guessing it won't have the date added, and you'll need to work back through your JSL to see why.
Or, perhaps the question is about turning the formula into JSL? Can you show the formula that added the date and the JSL you use for the upload?
