How to add the confidence intervals to a logistic regression plot?
I am trying to use the Fit Model in JMP to do logistic regression and draw a logistic plot (probability of response vs predictor). In that plot, it only shows a predicted line. Does anyone know how to add the 95% confidence interval to that plot? Here is the plot I want.
peng_liu
Re: How to add the confidence intervals to a logistic regression plot?
You may want to use GLM:
Then turn on Profiler:
peng_liu
It woks. Thanks for your help!
