lala
How to add special tags on top of this mapping?
For example, we use Big Class.jmp data to make height and weight distribution maps according to different ages.
Can you show the starting and ending heights of different ages in the table in the order of row numbers?
Of course, there is no limit to how it can be displayed.Screenshots just make the requirements clear.
ca = "R";
New Column( ca );
Column( ca ) << Formula( Row() );
dt << run formulas;
Column( ca ) << deleteFormula;
d2 = dt << Summary( Group( age ), Freq( 0 ), Weight( 0 ), Link to original data table( 0 ) );
d2 << Update( With( dt ), Match Columns( age = age ), Add Columns from Update table( height ) );
Column( d2, 3 ) << set name( "end" );
dt << Sort( By( R ), Order( Descending ), replace table );
Column( d2, 4 ) << set name( "beg" );
dt << Sort( By( R ), Order( Ascending ), replace table );
d2 << delete columns( 2 );
dt << Update( With( d2 ), Match Columns( age = age ) );
Re: How to add special tags on top of this mapping?
Column(dt, "name") << Label(0);
Column(dt, "height") << Label(1);
dt << Select Where(Row() == Col Min(Row(), :age)) << Label(1) << Colors("Red") << Clear Select;
dt << Select Where(Row() == Col Max(Row(), :age)) << Label(1) << Colors("Blue") << Clear Select;
gb = dt << Graph Builder(
	Variables(X(:weight), Y(:height), Group X(:age), Color(:sex)),
	Elements(
		Bar(X, Y, Legend(6), Response Axis("X")),
		Points(X, Y, Color(0), Legend(7), Summary Statistic("Mean"))
		Dispatch({"Points"}, "", OutlineBox, {Close(0)}),
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				7,
				Properties(0, {Marker("Pipe"), Marker Size(0), Transparency(0)}, Item ID("Mean", 1))
8 REPLIES 8
I'm confused what you wish to display and where: tags on mapping? starting and ending heights in the table? Red arrow? Green checkmark?
lala
p1=dt<<Graph Builder(
	Variables( X( :weight ), Y( :height ), Group X( :age ), Color( :sex ) ),
	Elements( Bar( X, Y, Legend( 8 ), Response Axis( "X" ) ) )
dt << Select Where(Row() == Col Min(Row(), :age)) << Label(1) << Clear Select;
dt << Select Where(Row() == Col Max(Row(), :age)) << Label(1) << Clear Select;
	Elements(
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				7,
lala
Thanks Experts!
This marked number can be further added with different colors or other distinctions.Enable to know which is the beginning and which is the end?
	Elements(
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				7,
lala
I added the total weight for each age to the graph so that the original marks don't show up again.How to modify the code.
Still need to consult an expert.Thanks!
d2=dt<<Summary(Group(age),sum(height),Freq("无"),Weight("无"),Link to original data table(0));
dt<<Update(With(d2),Match Columns(age=age));
Column(dt, "name") << Label(0);Column(dt, "height") << Label(1);
Variables(
X( :weight ),
Y( :height ),
Y( :"Sum(height)"n ),
Group X( :age ),
Color( :sex )
Elements(
Bar( X, Y, Legend( 5 ), Response Axis( "X" )),
Points(X, Y, Color(0), Legend(7), Summary Statistic("Sum"))
Dispatch(
"400",
ScaleBox,
{Legend Model(
7,
Elements(
Position( 1, 2 ),
Bar( X, Y, Legend( 6 ),
Response Axis( "X" ),
Summary Statistic( "Max" ),
Label( "Label by Value" )
Open the graph builders control panel and modify different variables for different plots to figure out what is possibly wrong.
lala
