Thanks for your further reply, Lou. I tried your 2nd solution for my problem. But I am new to JMP, so I am trying to be careful using custom design.
Here is what I did. I add one response to maximize it and seven continuous factors. In my model I add RSM to account for 1st and 2nd order interaction.
Because I want a modified fractional factorial design with a resolution of V, which should have 64 runs. So I specified here the runs to be 64 and get my design table.
Then my questions are
1) Will this design process solve my problem as a modified fractional factorial design with the "axial points" I want?
2) I don't need center points for my design, but I do get center points in this custom design table.
