Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
How to add a picture withine an outline in a journal?
Created:
Nov 30, 2020 11:03 AM
| Last Modified: Jun 10, 2023 1:41 PM(2585 views)
Hello everybody,
When you copy / paste a picture in a journal, JMP places it at the end of the journal. However I would like to place it within a specific outline so that when I close the outline, the picture is hidden. Do you know how to do that? Thanks
All you have to do is to select the picture using the selection tool "+" and then while holing the mouse button down, drag and drop the picture to where ever you want it to be in the journal.
