How to add a Search system/filter to Report?
Hey everyone, I was wondering if there is any way to add a search system into the report (preferably no add-ins) such that when I type the name of a variable into the search bar, the search will either bring me to the variable within the report or update the report such that it only shows the variable that has been typed in (the former is preferable). I want to be able to do this in JSL. Any solutions or demo code are greatly appreciated!
Cheers
Re: How to add a Search system/filter to Report?
var = dt << Variability Chart(
	Y(:NPN1),
	X(:wafer, :SITE),
	Always use column properties(1),
	Column Switcher(
		:NPN1,
		{:NPN1, :PNP1, :PNP2, :NPN2, :PNP3, :IVP1, :PNP4, :NPN3, :IVP2, :NPN4, :SIT1,
		:INM1, :INM2, :VPM1, :VPM2, :VPM3, :PMS1, :SNM1, :SPM1, :NPN5, :EP2, :ZD6,
		:PBA, :PLG, :CAP, :PBA3, :PLG2, :PNP5, :NPN6, :PNP6, :PNP7, :NPN7, :PNP8,
		:IVP3, :IVP4, :IVP5, :IVP6, :PNP9, :NPN8, :NPN9, :IVP7, :NPN10, :N_1, :PBA1,
		:WPR1, :B10, :PLY10, :VBE210, :VTN210, :VTP210, :SIT2, :SIT3, :INV2, :INV3,
		:INV4, :INV5, :FST1, :FST2, :RES1, :RES2, :PNM1, :PPM1, :FNM1, :FPM1, :FST3,
		:FST4, :RES3, :RES4, :A1, :B1, :A2N, :A2P, :A2P1, :IVP8, :IVP9, :DE_H1,
		:NF_H1, :ESM1, :ESM2, :ESP1, :YFU1, :VPM4, :PBA2, :PBB1, :LYA1, :LYB1, :DEM1,
		:DEP1, :NFM1, :PLY1, :VDP1, :VDP2, :SNW1, :RSP2, :PLY2, :RSP1, :VDP3, :PBL1,
		:PLG1, :VDP4, :SPW1, :VIA1, :INM3, :VPM5, :VPM6, :INM4, :VPM7, :M1_M1,
		:M2_M2, :P1_P1, :E2A1, :E2B1, :NPN11, :IVP10, :PNP10, :INM5, :VPM8, :VPM9,
		:INM6, :VPM10, :N2A1, :N2B1, :NM_L1, :P2A1, :P2B1, :PM_L1, :P1, :M1}
8 REPLIES 8
What do you mean by variable in this case?
Column names like age, height, weight etc.
And how do you want to filter them? Would using local data filter / column switcher would be enough for you needs?
Something like this would be good, the main point would be for the specific graph for to appear when i click/check/search for it.
After doing some research, a column switcher seems good, so does a local data filter.
After playing around with the column switcher, I realized that this is essentially what I want. I'm wondering if the column switcher has a search function like in image I shared in my previous comment (the search function that puts "Enter Column Name"):
If it is possible to do with this data filter, it would also be good
Column switcher does have search capabilities
Usually if you can do it with column switcher but not with data filter, you would have to stack your data to get it into format usable by filters.
Any idea how to code this in JMP JSL? I am currently struggling to add this into my section of code
This is for a variability chart
TCB512 = outlinebox("Attribute Monitoring",
For ( i=1, i<=N items(col_list), i++,
//print(kpps[i]);
::Var = /*TCB809*/
Variability Chart(
        Y( Column (myspfcsv, col_list[i]) ),
        X( :Name("col_1"),
           :Name("col_2"),
           :Name("col3"),
           :Name("col4"),
           :Name("col5"),
           :Name("col6"),
           :Name("column")
        Analysis Type( Name( "Choose best analysis (EMS REML Bayesian)" ) ),
	Dispatch( {}, "Variability Chart",FrameBox,Row Legend(:Name("col2"),Marker( 0 ),Marker Theme( "Shape" ))),
	Dispatch( {}, "Variability Chart",FrameBox,Row Legend(:Name("col3"),Marker( 1 ),Marker Theme( "Shape" ))),
        Dispatch( {}, "2", ScaleBox, {Show Major Grid( 0 ), Show Minor Grid( 0 )   }),
        Dispatch( {}, "Variability Chart", FrameBox, {Frame Size( 1400, 250 ), Background Color( -16777215 ), Marker Size( 5 )} ),
And this is for a Bivariate Plot
New Window("Time Trend Chart for Attribute (Filters)",
    // Add a data filter
    df = dt << Data Filter(
        Mode(Show(1)),
        Add Filter(
            Columns(
                :Name("col_1"),
                :Name("col_2"),
                :Name("col_3")
				:Name("col_1") == col1_values &
                :Name("col_2") == col2_values &
                :Name("col_3") == col3_values
    For(i = 1, i <= N Items(kpps), i++,
        ::Var = Bivariate(
            Y(Column(dt, kpps[i])),
            X(:Name("processtimestamp")),
            Analysis Type(Name("Choose best analysis (EMS REML Bayesian)"))
        // Get the report object
        rbiv = ::Var << Report;
        // Find the FrameBox
        framebox = rbiv[FrameBox(1)];
        // Modify the FrameBox
        framebox << Row Legend(:Name("col_1"), Marker(1), Marker Theme("Shape"));
        framebox << Row Legend(:Name("col_2"), Marker(0), Marker Theme("Shape"));
        framebox << Frame Size(1400, 250);
        framebox << Background Color(-16777215);
        framebox << Marker Size(5);
Just need a general idea as how to approach this/add it in
	Y(:NPN1),
	X(:wafer, :SITE),
	Column Switcher(
		:NPN1,
