TDK_Long
How to access one of the multiple data tables opened at the same time?
Hi folks,
I opened a couple data table by the following jsl,
dt = Multiple File Import();
After that, I tried to access one of the data table to process the data, what is the jsl script or command to access the the data table.
For example, if I need to access the 2nd data table row #2 and column #1, i used the command below:
dt[2][2,1]
but it did not work, please advise it, thanks.
Re: How to access one of the multiple data tables opened at the same time?
The following code works on JMP 16 and 17
names default to here( 1 );
dt=
	<<Set Folder( "<path to folder>"),
	<<Set Name Filter( "*.xls" ),
	<<Set Name Enable( 1 )
) << import data ;
dt[1][2,1]
dt=
) << import data ;
dt[1][2,1]
TDK_Long
Thank you Jim.
