MichaelO
How to Use a list of Columns as Analysis Columns in Tabulate?
I'm having an issue where I want to tabulate the sum and n for each test in a large testprogram. I'm not sure what my issue is, but would appreciate some guidance. The code compiles and outputs the Tabulate window as seen below, but isn't populated.
Below is the code I have written:
colList = dt << Get Column Names( string );
colname = Column(dt, "TEST_T") << getname;
testIndex = (Loc(colList, colname))[1];
numRows = N Rows(dt);
For(i = (testIndex + 1), i <= N Items(colList), i++,
	column = Column(dt, colList[i]);
	For(j = 1, j <= numRows, j++,
		column[j] = Substitute(column[j],
			"Pass", "1",
			"Fail", "0"
//Change Modeling Type for Tabulate functionality
dt:tst_temp << Set Modeling Type(Nominal);
dt:SITE_NUM << Set Modeling Type(Nominal);
////Change Every Column after TEST_T to Numeric Data Type and Continuous Modeling type
	column << Data Type(Numeric);
	column << Set Modeling Type(Continuous);
list = dt << Get Column Names( string );
Remove From(list, 1, testIndex);
yieldByTest = (dt << Tabulate(
		Add Table(
			Column Table(
				Grouping Columns(:tst_temp),
				Statisitcs(Sum, N)
			Row Table(
				Analysis Columns(Column(Eval(list)))
		),invisible
) << Make Into data Table;
yieldByTest << Set Name("Yield by Test Across Temperature");
Georg
Re: How to Use a list of Columns as Analysis Columns in Tabulate?
I think this works as an example,
in your script you have a typo "Statisics(Sum, N)"
// Get a list of all continuous Columns
colList = dt << Get Column Names( "Continuous" );
// Feed that list to Analysis Columns of Tabulate
dt << Tabulate(
	Add Table( Column Table( Analysis Columns( Eval( colList ) ), Statistics( Mean, N ) ), Row Table( Grouping Columns( :sex ) ) )
Georg
Please provide a sample of what your expected output is.
Georg
dt << Tabulate(
Georg
MichaelO
That is really disappointing - I just need to practice my spelling I guess!
MichaelO
Here is an example output from the Tabulate window. In practice the number of rows will be much larger. Follow up question, is there a way to get the Sum/N into a column for each temperature from the Tabulate window? I've been manually doing it, but was wondering if there is a simple way to do this from the Tabulate window?
