nikles
How to Remove a Distribution Comparison?
Hi.  I'd like to know if there's a way to remove a "Compare Distributions" from an existing Distribution platform output using JSL.  For example:
obj = Distribution(
	Column(:Height, :Weight),
	Fit Distribution("All")
//These are things I've tried to remove the CmpDist for the Height Distribution, but did not work:
obj[1] << Remove Fit;
obj[1] << (Fit Handle[1] << Remove Fit);
obj[1] << Fit Distribution(0);
I want to completely remove the "Compare Distributions" outline box and its contents, along with the fit curve in the plot.  IOW, as if I'd never issued the Fit Distribution("All") command at all for that distribution.  IOOW, as if I went to the red down arrow for the Height distribution > Continuous Fit and unchecked "All".
I have not yet attempted to delete the display boxes from the report window via brute force.  Hoping there's a simpler option?
Re: How to Remove a Distribution Comparison?
It is in the Help > Scripting Index and Help > Books > Scripting Guide.
obj = dt << Distribution(
obj << All(0);
obj << All(0);
nikles
Thanks.  This works, but for the life of me, I could not find this in the Scripting Guide.
