Ted
Ted
How to Change the Default Settings: Preferences -> Platforms -> ?
How to make agreement statistics (Cohen's kappa) to appear in the "Fit Y by X" platform report by DEFAULT?
Thank you very much for your help!
Re: How to Change the Default Settings: Preferences -> Platforms -> ?
in the preferences you can search for kappa, then you get almost immediately to agreement statistics in contingency analysis what should be what you are searching for
/****NeverStopLearning****/
