Buttinoni7
How to Add reference lines on Graph Builder script loop
I'm trying to automate graph generation which looks good but when adding the reference lines they're not plotted. How this can be accomplished through the loop?
As test I've also tried to give a number or the index to the Scalebox but nothing appear.
Data Table( "NC119_1" ) << Graph Builder(
	Page Gap Size( 1 ),
	Variables(
		X( :timeTrace ),
		Y( :VI2, Side( "Right" ) ),
		Y( :VI1, Position( 1 ) ),
		Page( :tracenum )
	Elements(
		Points( X, Y( 2 ), Legend( 1 ) ),
		Points( X, Y( 2 ), Legend( 2 ) ),
		Points( X, Y( 1 ), Legend( 3 ) ),
		Points( X, Y( 1 ), Legend( 4 ) ),
		by ( :tracenum )
For( i = 1, i <= 1, i++,
	Where( :tracenum == i ),
		Dispatch(
			"timeTrace",
			ScaleBox,
			{Format( "Fixed Dec", 12, 0 ), Min( -38.696 ), Max( 3200.00 ),
			Inc( 500 ), Minor Ticks( 1 )}
		Dispatch(
			"VI1",
			ScaleBox,
			{Format( "Fixed Dec", 12, 1 ), Min( -0.1367445006 ), Max( 2.5845443676 ),
			Inc( 0.5 ), Minor Ticks( 1 )}
		Dispatch(
			"VI2",
			ScaleBox,
			{Format( "Fixed Dec", 12, 3 ), Min( -1 ),
			Max( 0.01 ), Inc( 0.01 ), Minor Ticks( 0.1 )}
		Dispatch(
			"timeTrace",
			ScaleBox( 1 ),
			{Add Ref Line( 1200, "Solid", "Black", "", 1 )}
		Dispatch(
			"VI1",
			ScaleBox( 1 ),
			{Add Ref Line( 0.3, "Solid", "Black", "", 1 )}
Re: How to Add reference lines on Graph Builder script loop
This might give you a good idea how to move forward with this Re: Using JSL to add reference lines to Page By graphs  or at least how to get started.
