BabyDoragon
How should elements in a matrix be represented using variables?
How should elements in a matrix be represented using variables? For example, in following JSL, [1 -3] works properly, but [1 a] causes an error. How can this be fixed?
Word( [1 -3], "This is an apple", " " );
a=-3;
Word( [1 a], "This is an apple", " " );
Re: How should elements in a matrix be represented using variables?
Depending what you are trying to do, you can build it from a list for example
a =-3;
l = Eval List({1, a});
Word(Matrix(l)`, "This is an apple", " " );
