lala
Level IX
How is this regular expression replacement implemented
The regular expressions of EmEditor
to
How to modify JSL
",":["11000278031.胡剑","11000259239.胡慧","11000426432.叶子","11000445039.张大为","11000469637.詹浏洋","11000480631.李书颖"],","
to
",":["11000278031.胡剑&11000259239.胡慧&11000426432.叶子&11000445039.张大为&11000469637.詹浏洋&11000480631.李书颖"],","
Craige_Hales
Re: How is this regular expression replacement implemented
The original data rows contain fields that are arrays (author and authorID.) The stack option determines if those arrays make more rows.
unstacked keeps the multiple authors on one row:
vs stacked, which produces the 9 rows (the sampler won't always show all the values, but this time they all fit):
Unstacked can collapse the authorID like this (using expression to hold the authorID Col):
You can change the author field too, if it helps, but the comma separated list in the character field might be easier to use than an expression for the numeric field. Or you might prefer the authorID_N column names.
Above, I removed a bunch of columns (to focus on the author columns.) You can select multiple columns in the table view at the bottom and then click any selected Col in the top and change them all to "no column" to remove unwanted columns.
Craige
12 REPLIES 12
lala
Level IX
回复: How is this regular expression replacement implemented
txt="\!",\!":[\!"11000278031.胡剑\!",\!"11000259239.胡慧\!",\!"11000426432.叶子\!",\!"11000445039.张大为\!",\!"11000469637.詹浏洋\!",\!"11000480631.李书颖\!"],\!",\!"";
tx="";tx = Regex(txt, "\[","(?=[^\[\]]*\])]\", "&");
Thanks Experts!
Maybe something like this?
ames Default To Here(1);
str = "\[",":["11000278031.胡剑","11000259239.胡慧","11000426432.叶子","11000445039.张大为","11000469637.詹浏洋","11000480631.李书颖"],","]\";
res = Regex(str, "\[","(?=[^\[\]]*\])]\", "&", GLOBALREPLACE);
Write(res);
Craige_Hales
It is a truly obtuse pattern. I was so sure it wouldn't work I didn't even try it. So, why does it work?
The goal appears to be to replace the quote-comma-quote sequences, but only inside the [ square brackets ]. Somehow the positive look-ahead does that.
means "look ahead for zero or more characters that are not square brackets, followed by a close square bracket."
So the quote-comma-quote before the [ can't match because the regex can't locate the trailing ] without being stopped by the [.
And the final quote-comma-quote after the ] can't match because there is not another ].
and the quote-comma-quote in the middle ... work.
Cool, I guess. But actually a fair amount of work for the regex engine; the positive look ahead is scanning to the end of the string over and over. I would not leave this for a future maintainer to figure out without some comments, and I'd probably do it more like this:
source = "\[
Write( source );
findthis = "\!",\!""; // ","
replacewith = "&";
// goal: replace findthis
//       with replacethis
//       but only inside the [ ... ] square brackets.
If( 0 < Contains( source, "[" ) < Contains( source, "]" ), "ok", Throw( "something wrong here" ));
parts = Words( source, "[]" );
If( N Items( parts ) == 3, "ok", Throw( "this needs more thought" ));
Substitute Into( parts[2], findthis, replacewith );
result = parts[1] || "[" || parts[2] || "]" || parts[3];
Write( result );
https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Regular_expressions/Lookahead_asse...
Craige
lala
Level IX
Thank Craige!
Actually, I just want to know how this JSON can be turned into a perfect table
tx="\[[{"title":"AA,AA","BName":"AA","BCode":"605366","orgCode":"82004416","orgName":"AA","orgSName":"AA","publishDate":"2025-12-28 00:00:00.","infoCode":"AP202512281809952250","column":"002004006001","predictNextTwoYearB":"","predictNextTwoYearPe":"","predictNextYearB":"","predictNextYearPe":"","predictThisYearB":"","predictThisYearPe":"","predictLastYearB":"","predictLastYearPe":"","actualLastTwoYearB":"","actualLastYearB":"","industryCode":"","industryName":"","emIndustryCode":"","indvInduCode":"538","indvInduName":"AA","emBCode":"","emBValue":"","emBName":"","lastEmBCode":"","lastEmBValue":"","lastEmBName":"","BChange":"","reportType":2,"author":["11506051.AA"],"indvIsNew":"001","researcher":"AA","newListingDate":"2020-08-12 00:00:00.","newPurchaseDate":"2020-07-31 00:00:00.0","newIssueB":9.98,"newPeIssueA":22.78,"indvAimBT":"","indvAimBL":"","attachType":"0","attachSize":383,"attachPages":3,"encodeUrl":"6XT6d6nxZNcP9JXS1dtw9ivwowNnxWgBjsEKvrMIHoo=","sBName":"","sBCode":"","B":"SHANGHAI","authorID":["11506051"],"count":1,"orgType":"white"},{"title":"AAI,AA","BName":"AA","BCode":"688800","orgCode":"80036717","orgName":"AA","orgSName":"AA","publishDate":"2025-12-28 00:00:00.","infoCode":"AP202512281809913359","column":"002004001003","predictNextTwoYearB":"2.67","predictNextTwoYearPe":"32.97","predictNextYearB":"2.08","predictNextYearPe":"42.24","predictThisYearB":"1.46","predictThisYearPe":"60.44","predictLastYearB":"","predictLastYearPe":"","actualLastTwoYearB":"","actualLastYearB":"","industryCode":"","industryName":"","emIndustryCode":"","indvInduCode":"459","indvInduName":"AA","emBCode":"007","emBValue":"3","emBName":"AA","lastEmBCode":"007","lastEmBValue":"3","lastEmBName":"AA","BChange":3,"reportType":2,"author":["11392732.AA","11524834.AA"],"indvIsNew":"001","researcher":"AA,AA","newListingDate":"2021-07-22 00:00:00.","newPurchaseDate":"2021-07-12 00:00:00.0","newIssueB":15.02,"newPeIssueA":24.49,"indvAimBT":"","indvAimBL":"","attachType":"0","attachSize":764,"attachPages":5,"encodeUrl":"6XT6d6nxZNcP9JXS1dtw9snalC40a3QwRrj9tML8YAw=","sBName":"AA","sBCode":"0301","B":"SHANGHAI","authorID":["11392732","11524834"],"count":1,"orgType":"white"},{"title":"AA,AA","BName":"AA","BCode":"601038","orgCode":"80064","orgName":"AA","orgSName":"AA","publishDate":"2025-12-28 00:00:00.","infoCode":"AP202512281809893801","column":"002004002003","predictNextTwoYearB":"0.9","predictNextTwoYearPe":"15.7600","predictNextYearB":"0.8100","predictNextYearPe":"17.4900","predictThisYearB":"0.7900","predictThisYearPe":"17.9200","predictLastYearB":"","predictLastYearPe":"","actualLastTwoYearB":"","actualLastYearB":"","industryCode":"","industryName":"","emIndustryCode":"","indvInduCode":"910","indvInduName":"AA","emBCode":"007","emBValue":"3","emBName":"AA","lastEmBCode":"007","lastEmBValue":"3","lastEmBName":"AA","BChange":3,"reportType":2,"author":["11379333.AA"],"indvIsNew":"001","researcher":"AA","newListingDate":"2012-08-08 00:00:00.","newPurchaseDate":"2012-07-27 00:00:00.0","newIssueB":5.4,"newPeIssueA":14.44,"indvAimBT":"","indvAimBL":"","attachType":"0","attachSize":321,"attachPages":4,"encodeUrl":"6XT6d6nxZNcP9JXS1dtw9vuL66I7rHatL9vNIud7cP0=","sBName":"AA","sBCode":"0101","B":"SHANGHAI","authorID":["11379333"],"count":1,"orgType":"white"},{"title":"AA:AA,AA","BName":"AA","BCode":"002488","orgCode":"80162","orgName":"AA","orgSName":"AA","publishDate":"2025-12-25 00:00:00.","infoCode":"AP202512251807934364","column":"002004001003","predictNextTwoYearB":"1.0100","predictNextTwoYearPe":"8.4","predictNextYearB":"0.3300","predictNextYearPe":"25.4","predictThisYearB":"0.0600","predictThisYearPe":"131.8","predictLastYearB":"","predictLastYearPe":"","actualLastTwoYearB":"","actualLastYearB":"","industryCode":"","industryName":"","emIndustryCode":"","indvInduCode":"481","indvInduName":"AA","emBCode":"007","emBValue":"3","emBName":"AA","lastEmBCode":"","lastEmBValue":"","lastEmBName":"","BChange":2,"reportType":2,"author":["11250834.AA","11245529.AA","11442637.AA"],"indvIsNew":"001","researcher":"AA,AA,AA","newListingDate":"2010-10-21 00:00:00.","newPurchaseDate":"2010-10-11 00:00:00.0","newIssueB":22,"newPeIssueA":73.33,"indvAimBT":"","indvAimBL":"","attachType":"0","attachSize":2285,"attachPages":19,"encodeUrl":"MKF7cC+MZ9vDOQWsqD7ZgmRE9eUeYHJK9njuGLTcICI=","sBName":"AA(1)","sBCode":"0201","B":"SHENZHEN","authorID":["11250834","11245529","11442637"],"count":1,"orgType":"white"},{"title":"BDAA,AA","BName":"AA","BCode":"688621","orgCode":"80064","orgName":"AA","orgSName":"AA","publishDate":"2025-12-25 00:00:00.","infoCode":"AP202512251807725254","column":"002004006003","predictNextTwoYearB":"2.4600","predictNextTwoYearPe":"28.0","predictNextYearB":"2.2600","predictNextYearPe":"30.5400","predictThisYearB":"1.8","predictThisYearPe":"38.3300","predictLastYearB":"","predictLastYearPe":"","actualLastTwoYearB":"","actualLastYearB":"","industryCode":"","industryName":"","emIndustryCode":"","indvInduCode":"727","indvInduName":"AA","emBCode":"007","emBValue":"3","emBName":"AA","lastEmBCode":"007","lastEmBValue":"3","lastEmBName":"AA","BChange":3,"reportType":2,"author":["11296231.AA","11486715.AA"],"indvIsNew":"001","researcher":"AA,AA","newListingDate":"2021-06-21 00:00:00.","newPurchaseDate":"2021-06-09 00:00:00.0","newIssueB":26.89,"newPeIssueA":29.72,"indvAimBT":"","indvAimBL":"","attachType":"0","attachSize":315,"attachPages":4,"encodeUrl":"MKF7cC+MZ9vDOQWsqD7ZgvFJHAi4XRobbkVOxAB2GK4=","sBName":"AA","sBCode":"0101","B":"SHANGHAI","authorID":["11296231","11486715"],"count":1,"orgType":"white"}]]\";
 d1 =jsontodatatable(tx);
This will increase the number of lines
lala
Level IX
Four rows have been added
That's why I came up with this stupid idea
JMP does offer JSON Import Wizard.
Is there a specific reason to avoid using that first? When you figure out which options to use that you can try to transform them to JSON To Data Table as it does offer you with some parameters such as Guess() or JSON Settings()
lala
Level IX
It can only be operated manually once
Thanks Experts!
You do it once manually to let JMP assist you in scripting like you always should do with graphs, platforms and table transforms.
Create a .json file from your string
Use JMP's Open and locate the file and open it as Using Preview
Try different options in the wizard. This is the result after just using Wide guess
Export it to JMP if it looks fine. Check Source table script
This could be OK for you if the structure is already the same. If not, go to scripting index/jmp help and check if Open has any better options to use. Quickly looking it doesn't, look for JSON from Scripting Index. Come across JSON To Data Table which seems to have mention of Guess and "Wide"
Click Topic Help to get useful information about the argumentsJSON To Data Table(JSON string, (<Private(Boolean)>|<Invisible(Boolean)>), <Guess(Stack(Boolean)|"Ta...
Remember that you used "Wide" Guess in the JSON Wizard.
Modify your script to use Guess with JSON To Data Table
View more...
json = "\[[{"title":"AA,AA","BName":"AA","BCode":"605366","orgCode":"82004416","orgName":"AA","orgSName":"AA","publishDate":"2025-12-28 00:00:00.","infoCode":"AP202512281809952250","column":"002004006001","predictNextTwoYearB":"","predictNextTwoYearPe":"","predictNextYearB":"","predictNextYearPe":"","predictThisYearB":"","predictThisYearPe":"","predictLastYearB":"","predictLastYearPe":"","actualLastTwoYearB":"","actualLastYearB":"","industryCode":"","industryName":"","emIndustryCode":"","indvInduCode":"538","indvInduName":"AA","emBCode":"","emBValue":"","emBName":"","lastEmBCode":"","lastEmBValue":"","lastEmBName":"","BChange":"","reportType":2,"author":["11506051.AA"],"indvIsNew":"001","researcher":"AA","newListingDate":"2020-08-12 00:00:00.","newPurchaseDate":"2020-07-31 00:00:00.0","newIssueB":9.98,"newPeIssueA":22.78,"indvAimBT":"","indvAimBL":"","attachType":"0","attachSize":383,"attachPages":3,"encodeUrl":"6XT6d6nxZNcP9JXS1dtw9ivwowNnxWgBjsEKvrMIHoo=","sBName":"","sBCode":"","B":"SHANGHAI","authorID":["11506051"],"count":1,"orgType":"white"},{"title":"AAI,AA","BName":"AA","BCode":"688800","orgCode":"80036717","orgName":"AA","orgSName":"AA","publishDate":"2025-12-28 00:00:00.","infoCode":"AP202512281809913359","column":"002004001003","predictNextTwoYearB":"2.67","predictNextTwoYearPe":"32.97","predictNextYearB":"2.08","predictNextYearPe":"42.24","predictThisYearB":"1.46","predictThisYearPe":"60.44","predictLastYearB":"","predictLastYearPe":"","actualLastTwoYearB":"","actualLastYearB":"","industryCode":"","industryName":"","emIndustryCode":"","indvInduCode":"459","indvInduName":"AA","emBCode":"007","emBValue":"3","emBName":"AA","lastEmBCode":"007","lastEmBValue":"3","lastEmBName":"AA","BChange":3,"reportType":2,"author":["11392732.AA","11524834.AA"],"indvIsNew":"001","researcher":"AA,AA","newListingDate":"2021-07-22 00:00:00.","newPurchaseDate":"2021-07-12 00:00:00.0","newIssueB":15.02,"newPeIssueA":24.49,"indvAimBT":"","indvAimBL":"","attachType":"0","attachSize":764,"attachPages":5,"encodeUrl":"6XT6d6nxZNcP9JXS1dtw9snalC40a3QwRrj9tML8YAw=","sBName":"AA","sBCode":"0301","B":"SHANGHAI","authorID":["11392732","11524834"],"count":1,"orgType":"white"},{"title":"AA,AA","BName":"AA","BCode":"601038","orgCode":"80064","orgName":"AA","orgSName":"AA","publishDate":"2025-12-28 00:00:00.","infoCode":"AP202512281809893801","column":"002004002003","predictNextTwoYearB":"0.9","predictNextTwoYearPe":"15.7600","predictNextYearB":"0.8100","predictNextYearPe":"17.4900","predictThisYearB":"0.7900","predictThisYearPe":"17.9200","predictLastYearB":"","predictLastYearPe":"","actualLastTwoYearB":"","actualLastYearB":"","industryCode":"","industryName":"","emIndustryCode":"","indvInduCode":"910","indvInduName":"AA","emBCode":"007","emBValue":"3","emBName":"AA","lastEmBCode":"007","lastEmBValue":"3","lastEmBName":"AA","BChange":3,"reportType":2,"author":["11379333.AA"],"indvIsNew":"001","researcher":"AA","newListingDate":"2012-08-08 00:00:00.","newPurchaseDate":"2012-07-27 00:00:00.0","newIssueB":5.4,"newPeIssueA":14.44,"indvAimBT":"","indvAimBL":"","attachType":"0","attachSize":321,"attachPages":4,"encodeUrl":"6XT6d6nxZNcP9JXS1dtw9vuL66I7rHatL9vNIud7cP0=","sBName":"AA","sBCode":"0101","B":"SHANGHAI","authorID":["11379333"],"count":1,"orgType":"white"},{"title":"AA:AA,AA","BName":"AA","BCode":"002488","orgCode":"80162","orgName":"AA","orgSName":"AA","publishDate":"2025-12-25 00:00:00.","infoCode":"AP202512251807934364","column":"002004001003","predictNextTwoYearB":"1.0100","predictNextTwoYearPe":"8.4","predictNextYearB":"0.3300","predictNextYearPe":"25.4","predictThisYearB":"0.0600","predictThisYearPe":"131.8","predictLastYearB":"","predictLastYearPe":"","actualLastTwoYearB":"","actualLastYearB":"","industryCode":"","industryName":"","emIndustryCode":"","indvInduCode":"481","indvInduName":"AA","emBCode":"007","emBValue":"3","emBName":"AA","lastEmBCode":"","lastEmBValue":"","lastEmBName":"","BChange":2,"reportType":2,"author":["11250834.AA","11245529.AA","11442637.AA"],"indvIsNew":"001","researcher":"AA,AA,AA","newListingDate":"2010-10-21 00:00:00.","newPurchaseDate":"2010-10-11 00:00:00.0","newIssueB":22,"newPeIssueA":73.33,"indvAimBT":"","indvAimBL":"","attachType":"0","attachSize":2285,"attachPages":19,"encodeUrl":"MKF7cC+MZ9vDOQWsqD7ZgmRE9eUeYHJK9njuGLTcICI=","sBName":"AA(1)","sBCode":"0201","B":"SHENZHEN","authorID":["11250834","11245529","11442637"],"count":1,"orgType":"white"},{"title":"BDAA,AA","BName":"AA","BCode":"688621","orgCode":"80064","orgName":"AA","orgSName":"AA","publishDate":"2025-12-25 00:00:00.","infoCode":"AP202512251807725254","column":"002004006003","predictNextTwoYearB":"2.4600","predictNextTwoYearPe":"28.0","predictNextYearB":"2.2600","predictNextYearPe":"30.5400","predictThisYearB":"1.8","predictThisYearPe":"38.3300","predictLastYearB":"","predictLastYearPe":"","actualLastTwoYearB":"","actualLastYearB":"","industryCode":"","industryName":"","emIndustryCode":"","indvInduCode":"727","indvInduName":"AA","emBCode":"007","emBValue":"3","emBName":"AA","lastEmBCode":"007","lastEmBValue":"3","lastEmBName":"AA","BChange":3,"reportType":2,"author":["11296231.AA","11486715.AA"],"indvIsNew":"001","researcher":"AA,AA","newListingDate":"2021-06-21 00:00:00.","newPurchaseDate":"2021-06-09 00:00:00.0","newIssueB":26.89,"newPeIssueA":29.72,"indvAimBT":"","indvAimBL":"","attachType":"0","attachSize":315,"attachPages":4,"encodeUrl":"MKF7cC+MZ9vDOQWsqD7ZgvFJHAi4XRobbkVOxAB2GK4=","sBName":"AA","sBCode":"0101","B":"SHANGHAI","authorID":["11296231","11486715"],"count":1,"orgType":"white"}]]\";
dt_json = JSON To Data Table(json, Guess(Stack(0), "Wide"));
Craige_Hales
Craige
