elb89
How is power calculated in optimal designs?
How is power calculated in optimal designs? I designed a D-optimal split-split plot experiment, and as in classical split-split-plot designs, the power associated with the main plots and subplots are lower than the sub-sub plots, but I struggle to understand if power (and effect size) calculations in optimal designs are computed the same way as classical designs. In other words, how does applying optimality criteria affect the treatment structure/variance partitioning?
Re: How is power calculated in optimal designs?
The power calculation is the same. The power depends on the design, not the design method.
