dlifke
How do I multiply all data values by a multiplier for each column that is identified in another table?
How do I multiply all data values by a multiplier for each column that is in another table, by column name? (The multiplier table has a column with the column names and a second column with the multipliers to apply to each column in the other table. Not all columns have a multiplier.) I can get as far as adding the multiplier to the data table in its own row, but then I'm stuck. I know I can do it quickly externally but I’m sure there’s a way to do it in JMP.
Re: How do I multiply all data values by a multiplier for each column that is identified in another table?
Here is a simple example of changing the values in the Big Class data table, based upon a config data table as you describe.
// Open Data Table: big class.jmp
// → Data Table( "big class" )
dtConfig = New Table( "Config",
	New Column( "Name", character, values( {"age", "height", "weight"} ) ),
	New Column( "multiplier", values( {3, ., 2} ) )
dtColNames = dt << get column names( string );
For( i = 1, i <= N Rows( dtConfig ), i++,
	If( Contains( dtColNames, dtConfig:Name[i] ) & Is Missing( dtConfig:multiplier[i] ) == 0,
		temp = Column( dt, dtConfig:Name[i] ) << get values;
		temp = temp :* dtConfig:multiplier[i];
		Column( dt, dtConfig:Name[i] ) << set values( temp );
dlifke
Thanks! I passed it along to the internal customer. I presume the middle section dtConfig would not be necessary, since the multiplier table already exists. (You were just creating a new multiplier table to use on big class as an example.)  In the For loop he'd just replace dtConfig with the name of his multiplier table. Does that sound about right? Thanks again!
You are correct....
