How does JMP calculate the Std Error of means and Std Error of Diff in the LS means Table and LS Means Differences Student's t.
I tried to replicate the results by STD error calculated from both Standard deviation of sample and population,
but the values do not match.
Please refer the document attached, I calculated the  STD errors from the values in 4 groups as well as the
STD error of the 4 means in in my validation data set. I am not able to match it with the output of JMP.
Please point me to where I am going wrong.
Thanks
