lwx228
Level VIII
How does JSL's sorting operation not create a new window?
The result of sorting will not create a new window.But the same sort operation using the following JSL will produce a new window to display the sorted results.How do you make a JSL sorting operation not generate a new window?thank you!
dt = Current Data Table();
dt<<Sort(By(4),Order(descending));
Re: How does JSL's sorting operation not create a new window?
Here is the example from the Scripting Index
     Help==>Scripting Index
that illustrates the Replace Table option for the Sort Platform
dt << Sort(
	replace table,
	By( :name ),
	Order( Ascending )
pmroz
It's in the scripting index.  Look for sort and you'll see all of the options.
dt = Open( "$sample_data\Big Class.jmp" );
dt << Sort( By( 4 ), Order( descending ), replacetable( 1 ) );
dt << Sort(
	replace table,
	By( :name ),
	Order( Ascending )
pmroz
lwx228
Level VIII
replacetable
thanks you!
