lala
How does JSL implement the sorting of memory arrays?
ar = dt << GetAsMatrix( {2, 4} );
ar << Sort( By( 1 ), Order( Descending ), replace table );//??
  • Of course, this code is just a try.
Re: How does JSL implement the sorting of memory arrays?
You might find something in Sorting Lists  useful. The Rank() function is often overlooked.
You can sort vectors and lists but I'm not sure if you can sort matrix by specific column. But you can always convert that matrix to private table, sort it and get it back into matrix.
ar = dt << GetAsMatrix({2, 4});
dt_m = As Table(ar, <<private);
dt_m << Sort(By(1), Order(Descending), Replace Table);
ar1 = dt_m[0,0];
Close(dt_m, no save);
show(ar, ar1);
