baiyun
How does JMP initiate the values of w and b for logistic regression loss function? How to simulate the same iterations as JMP reports?
I have got some questions about the LR model.
- How does JMP initiate the values of w and b for logistic regression loss function?
- How does Relative Gradient derive(formula of this value)?
- What is the difference between Relative Gradient and NormGradient?
- Which parameter does this gradient value represent? w or b?
- Why no mention of the gradient update of the b(interception) parameter?
I just want to simulate the iteration as JMP did, the above questions stuck me from repeating this iteration. Look forward to your awesome reply!
Phil_Kay
Re: How does JMP initiate the values of w and b for logistic regression loss function? How to simulate the same iterations as JMP reports?
I've searched the JMP Help documentation but I can't find much explanation of the Iterations report:
https://www.jmp.com/support/help/en/16.0/#page/jmp/iterations.shtml#
I suggest that you contact JMP Technical Support to find out more.
Phil
