TreiderBest
How do you change the default color of box plot lines?
Hi, I don't like that the default color for box plots is red, while the first legend color in the JMP default palette is red. It's hard to see the box plot lines! Is there a way to change the default color for box plots? I'm running JMP 13.2.1. Thank you!
Re: How do you change the default color of box plot lines?
Here is an example in Graphg Builder:
Simply right-click on the marker in the legend and choose Color. You can do the same thing for the lines that make the box plot.
TreiderBest
@Mark_Bailey I was hoping for a way to set the default color to black for all box plots so I never had to change it later on, but this is a nice workaround, thank you.
