Andyon98
How do you append a list onto a col list box?
The syntax is causing me confusion, I tried something similar as below. However it does not work.
colbox << append(dt << mylist);
Re: How do you append a list onto a col list box?
Here is an example I took from the Scripting Index with a little modification to show you what you want
New Window( "Example",
	fontobj = lb = List Box({},
		width( 200 ),
		max selected( 2 ),
		nlines( 6 )
theList = {"First Item", "Second Item", "Third Item"};
lb << Append( theList );
Andyon98
That works correctly - in my application I have a list of lists but it wont work for some reason. See your code below slightly edited.
		width( 200 ),
		max selected( 2 ),
		nlines( 6 )
theList = {{"First Item", "Second Item", "Third Item"},{"Fourth Item", "Fifth Item", "Sixth Item"}};
//Im trying to pull the second list from the list of lists for(i=1, i=3, i++, lb << Append( theList[2][i] ); );
Your For Loop is in error.  It should be
for(i=1, i<=3, i++,
ErraticAttack
No need to loop:
		width( 200 ),
		max selected( 2 ),
		nlines( 6 )
lb << Append( theList[2] );
Jordan
