AT
AT
How do you Pass Arguments from JMP to Python script?
I like to pass a string (file name) to a Python Script using RunProgram. Here is the script:
file = "mtest.py abc.pdf";
RunProgram(executable("/usr/bin/python"),options({file}),readfunction("text"));
I appreciate your help. Thanks.
ih
Super User (Alumni) ih
Re: How to Pass Arguments from JMP to Python script?
You need to pass two different arguments through RunProgram as a list, because you are actually passing two arguments to python.  I do not have a mac, but on windows this python script:
import sys
print(sys.argv[1])
and this jsl script:
RunProgram(
	executable("C:\path to\python.exe"),
	options({"C:/path to/pythonscript.py", "hi"}),
returns:
"hi
nascif_jmp
Keep an eye out for JMP 14.0 and the new Python Submit() command.
It will allow you to call Python code directly from JSL, passing and receiving data structures - no RunProgram() required.
ih
import sys
print(sys.argv[1])
RunProgram(
returns:
"hi
AT
AT
Thanks. I will give it a try.
nascif_jmp
AT
AT
Thanks. It is good to know.
