KRT
KRT
How do I write a script to recode to remove partial text?
I am trying to write a script that converts any occurrence where a number is within the text "saturated ()", to remove the saturated (), leaving only the number.  I thought I could edit a recode script, but had no success.  Thank you in advance.
dt = Data Table( "Book1_Sheet1" );
dt << Begin Data Update;
dt << Recode Column(
    dt:Area,
    {Map Value(
        _rcOrig,
        {"saturated( ######### )", "#########"},
        Unmatched( _rcNow )
    Update Properties( 1 ),
    Target Column( :Area )
dt << End Data Update;
Re: How do I write a script to recode to remove partial text?
Try this. I tried to write the regular expression to recognize any correctly formatted number and ignore blanks or incorrectly formatted numbers.
	dt:Area,
	{Regex(
		_rcNow,
		"^saturated\((\-*)([\d\.]+)([eE]*)(\-*)(\d*)\)",
		"\1\2\3\4\5",
		GLOBALREPLACE
Here is one way to change the values
For Each Row(
	If( Left( :Area, 10 ) == "saturated(",
		:Area == Word( 2, :Area, "()" )
