apploarcher
How do I use the Col Maximum Formula with a "where" condition
Hi, I have a problem where I want to formulate a new column as a benchmark to all other countries. If there are more rows for the country, I want to take the max value of it as the benchmark. See the example below for clarification.
Data kind of looks like this:
Country       Value         period
A                  10              201301
A                  30              201301
B                  20              201301
C                  50              201301
D                  40              201301
What I want to achieve (with cell formula): Col Maximum (:value, :period, :country) where :country == "A"
Output:
Country       Value         period        BenchMark
A                  10              201301          30
A                  30              201301          30
B                  20              201301          30
C                  50              201301          30
D                  40              201301          30
As you can see, I want to benchmark the max value of only country A.
I tried Col Maximum (:value, :period, :country == "A") and it will return "50"
Col Maximum (:value, :period, :country) and Col Maximum (:value, :period, :country == "A") both returns "50"
I am pretty sure there's a simple solution for this!
Hope you guys can help!
Thanks thanks!
20 REPLIES 20
hogi
Level XIII
Re: How do I use the Col Maximum Formula with a "where" condition
2025 - JMP19 comes with a significant speed improvement for string comparisons.
cool!
Besides that, the suggested
col Mean(:weight, :age, where(not(excluded())))
was introduced for transform columns in reports. It got as compact as:
On the other hand, it's still very difficult to get the right formula for an  aggregation restricted to e.g.  :sex="M":
if(:sex=="M"& not(excluded()),
col Max
( if(:sex=="M", :weight,.), :age, excluded())
Something like
col Max(:weight, :age,  @excluded, where(:sex=="M"))
could help a lot.
Hm:  Col Median (and others): add "Where" option   : 1 Kudo in 3.5 years?! strange.
