PowerOx327
How do I use contains function to find a part of a variable name?
I'm trying to find a way to execute a function which happens when a list contains the string "[String]" like so:
AAList = {"object1", "object2", "object3[String]"};
If( Contains( AAList, "[String]"),
Show("string is running") );
But the if function isn't executed because the contains function doesn't detect the "[String]".
Any way to solve this?
Re: How do I use contains function to find a part of a variable name?
Contains is looking for full matches from a list, that why it won't find the which is part of one of the items in the list [String]. You can convert the list to a string using Concat Items()
If(Contains(Concat Items(AAList, "¤"), "[String]"),
Or loop over the list and break when match is found.
