Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMPĀ® Marketplace
TheRealYeti
How do I stop UI from looking like it hang up while doing long for loop operation
I made I UI that lets the user choose which process, temperature and voltage to include in the computation of Cpk, the script will iterate over each combination of process, temperature and voltage. I noticed that the UI hangs up while it is doing its operation. Is there a way to avoid this? I think a function similar to DoEvents in vb6 or better, a background process worker ?
pmroz
Re: How do I stop UI from looking like it hang up while doing long for loop operation
If you're looping in JSL you could add calls to caption() to inform the user of progress.
for (i = 1, i <= 1000000, i++,
	a = i*2;
	b = a^i;
	if (mod(i, 1000) == 0,
		caption("Processing ... " || char(i));
		wait(0);
caption(remove);
gzmorgan0
@TheRealYeti ,
I'll attack your question from another direction, your script might be inefficient. I have seen scripts that took hours to run, rewritten to run in a minute or two. Without more details, it is difficult to assess that.
Given that you know vb6, you could get the user input and your script could generate a JSL script to do the work, but run it via VB6 that uses DoEvents.  I do not know that function nor am I a VB expert.
The JMP documentation "Automation Reference" points you to many of the JMP library functions exposed to VB.
To create a JMP session and make it visible, add the following code to your VB
script.
Dim MyJMP As JMP.Application
Dim JMPDoc As JMP.Document
Set MyJMP = CreateObject("JMP.Application")
MyJMP.Visible = True
The JMP library function, Run JSL,
Run JSL file
Not sure if any of that helps.
TheRealYeti
My code runs in under a minute. My concern is that during the process, the GUI (made in JSL) would look like it stopped responding. I think  this is because the script and the GUI both run in the same thread (I could be wrong). In VB6, adding DoEvents command inside the for loop can be a quick solution, it allows the UI to update its elements and appear responsive but the total operation would take longer.
I'd like the script to be integrated in JMP itself and making it an add-in so other users can just install it and reuse it. If I go down the VB6 path, I'd rather do it completely in VB6, vs generating JSL script using VB6 then execute it. Thank you for giving different approach I appreciate every feedback.
pmroz
	a = i*2;
	b = a^i;
		wait(0);
caption(remove);
TheRealYeti
It looks like wait is what I need!
I will take a look at @David's suggestion next.
David_Burnham
If you are performing a number of time consuming discrete tasks you can use this status widget:
Activity Status Class
It will give the user status of progress and force screen updates.
-Dave
or modify code like Progress Bar  to meet your needs. @David_Burnham 's status class looks nice too!
