jpol
How do I set up a constraint when using Bayesian Optimization?
I have been evaluating the Bayesian Optimization platform with some success.
In order to run trials quickly I have been using SigmaZones's virtual catapult         Six Sigma Virtual Catapult - SigmaZone
BO was very efficient in achieving the targets set in the exercises for up to 4 input factors (9 total runs from a 4-factor experiment).
I attempted to evaluate performance using 5 factors :
Bungee Position
Cup Elevation
Firing Angle
Pin Elevation
Release Angle
My historical trials were as follows:
As I advanced through the BO iterations, I noticed that a certain combination of factors resulted in the ball being dropped and not projected. I needed to set up a constraint:
Constraint:  (Release Angle – Firing Angle) should never be less than 30
Something like this:
I exported the Candidate set and set up the constraints by removing the "forbidden" combinations. However after modifying and uploading the Candidate set Set, BO continued with the original Candidate set after the next iteration. It did not use the uploaded, constrained Candidate set.
What is the correct way to modify and "freeze" the constrained Candidate set?
P.S. Should anybody want to run this same exercise, here are the Coding properties:
The Target is to project a ball 545 mm +/- 20mm
Have Fun!
- Philip
11 REPLIES 11
jpol
Re: How do I set up a constraint when using Bayesian Optimization?
HI statman,
Thanks for these. Yes, I am familiar with the helicopter experiments. Great fun!
FYI the catapult simulator I used has two different modes of operations. A very well-hidden feature on the bottom left of the main screen. This allows for the introduction of noise.
- Philip
@jpol and @statman I've really enjoyed your dialogue here, those quotes are beautiful and thanks to your collaborative spirit and interest in discussion, we all get to benefit. It's no wonder I've always felt (intuited) that applied statistical learning is deeper and more concrete for me in the context of experimentation (formally designed or otherwise) on actual real-life experiments (that I've run myself or have been involved closely with in the planning and execution).
And Thanks @Victor_G for aptly pointing out how a constraint can be generated/ enforced and saved to the data table script automatically within Bayes Opt using the Augmented Prediction Profiler, specifically under the Linear Constraints Outline, available under the Optimization outline (Augmented Prediction Profiler red triangle menu > Optimization and Desirability> Optimization Control Panel) and within the Factors Tab (clicking on "Add Linear Constraint" Button).
