BeefSupreme
How do I search for unique values in column and use in input window?
I have a table that looks something like this, what I would like to do is search the "Cup Color" column for unique values, then have a pop-up window for the user to input a corresponding flavor for each unique cup color...
Cup ColorCaloriesTasteRankingTester
blue140421
green80714
yellow200236
purple130364
blue140352
blue140443
yellow200571
Once we have a flavor for each cup color, I would like to add a new column which is populated based on the the input that we got from the user.
Cup ColorCaloriesTasteRankingTesterFlavor
blue140421cherry
green80714raspberry
yellow200236chocolate
purple130364really minty
blue140352cherry
blue140443cherry
yellow200571chocolate
I'm still pretty new to JSL and have spent the last several hours going through forums looking for some guidance but can't seem to piece this together, a little help would be much appreciated.
Re: How do I search for unique values in column and use in input window?
Welcome to the community.
First, I have a suggestion on how to speed up your learning of JSL.
     Read the Scripting Guide!!!!
It is available at
     Help==>Books==>Scripting Guide
Below is a barebones script to accomplish what you requested.
dt = New Table( "Untitled 2",
	Add Rows( 7 ),
	New Column( "Cup Color",
		Character,
		"Nominal",
		Set Selected,
		Set Values( {"blue", "green", "yellow", "purple", "blue", "blue", "yellow"} )
	New Column( "Calories",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [140, 80, 200, 130, 140, 140, 200] )
	New Column( "Taste",
		Numeric,
		"Continuous",
		Set Values( [4, 7, 2, 3, 3, 4, 5] )
	New Column( "Ranking",
		Numeric,
		"Continuous",
		Set Values( [2, 1, 3, 6, 5, 4, 7] )
	New Column( "Tester",
		Numeric,
		"Continuous",
		Set Values( [1, 4, 6, 4, 2, 3, 1] )
// Get the list of unique colors
Summarize( dt, colorList = by( :Cup Color ) );
// Initialize the flavor list and make it the same
// length as the colorList
flavorList = {};
For( i = 1, i <= N Items( colorList ), i++,
	Insert Into( flavorList, "" )
// Create the display window
nw = New Window( "Select Flavors",
	Text Box( "Enter in Flavors for each Color" ),
	tb = Table Box(
		String Col Box( "Colors", colorList ),
		scb = String Col Edit Box( "Flavors", flavorList )
	Button Box( "OK",
		nw << close window;
		// Create the flavor table and update it to
		// the original table
		dt2 = New Table( "combined",
			New Column( "Cup Color", character, set values( colorList ) ),
			New Column( "Flavors", character, set values( flavorList ) )
		dt << Update( With( dt2 ), Match Columns( :Cup Color = :Cup Color ) );
		close( dt2, nosave );
// Set the String Col Edit Box action
scb << Set Function( Function( {this, which}, flavorList[which] = scb << get( which ) ) );
It is available at
	Add Rows( 7 ),
		Character,
		"Nominal",
		Set Selected,
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
flavorList = {};
	tb = Table Box(
	Button Box( "OK",
		nw << close window;
BeefSupreme
Perfect, thanks!
BeefSupreme
I actually need for my script to wait for the user input before progressing.
I found in the scripting guide that I can do this by using the modal message and thought that I got it added in correctly, but when I run the script I now the table doesn't update - log says "Name Unresolved: Button in access or evaluation of 'Button' , Button( 1 ) /*###*/"
flavorList = {};
	<< Modal,
	tb = Table Box(
	Button Box( "OK",
		nw << close window;
Using a Modal window is a very unique type of window.  There are several rules that you must follow.  One of which involves a Button Box with the text of "OK".  It has a special function in a modal window.  So you can use them, but you will need to study up on them, and do some practicing with them.
My preference is not to use Modal windows, but rather use Functions() or Expr() elements to encapsulate the code, keeping it from being executed until the script indicates it should be run.  Below is a simple example of how to do that.
flavorList = {};
	//<< Modal,
	tb = Table Box(
	Button Box( "OK",
		nw << close window;
		runAdditionalCodePlease;
runAdditionalCodePlease = Expr(
	Dialog("This represents the kind of things that",
		"you may want to run after the data entry.",
		"By placing the code inside an Expr() or in",
		"a Function().  The code will be run only",
		"when executed within the code."
