Niros
How do I run multiple CMD commands?
I am trying to do a simple extract of a zip file (TGZ) from JMP using the command prompt, and I don't manage to do it using the following approach (I tried many ridiculous ideas, none seem to work...):
path1="C:/Users/niros/Downloads/";
path2="C:/Program Files/WinRAR/WinRAR.exe";
path3="C:/Users/niros/Downloads/LP.tgz";
RP = RunProgram(
	Executable( "CMD.EXE" ),
	Options( { {"cd", path1}, {"mkdir", "testing"}, {"cd", "testing"}, {path2,"x", path3} } ),
	Read Function("text")
Niros
Re: How do I run multiple CMD commands?
Thank You All Many Times! PMROZ Your answer is exactly what I was looking for!
The last fault on my part is the space in the path which is easily solved with the \!" character...
Solution:
path2="\!"C:/Program Files/WinRAR/WinRAR.exe\!"";
// Create a command file to run multiple commands
cmd_file_text = evalinsert(
"rem Run multiple commands\!N
cd ^path1^\!N
mkdir testing\!N
cd testing\!N
^path2^ x ^path3^\!N
pause\!N
cmd_file_name = "c:\temp\run_commands.cmd";
// Save command file to disk
save text file(cmd_file_name, cmd_file_text, mode("replace"));
// The /c option carries out the command before terminating
run_cmds = runprogram(executable("cmd.exe"), options("/c " || cmd_file_name), readfunction("text"));
nw = new window("Output", << modal,
	panel box("CMD output:",
		text box(run_cmds, set width(800), set wrap(800),
				<< Set Font( "Courier New" )),
Example 3 in the scripting index
RunProgram set up to feed commands to CMD.exeRunProgram set up to feed commands to CMD.exe
is one way.
Another way would use a command separator within the parameters. Modified from example 1:
RP = Run Program(
    Executable( "CMD.EXE"/*path probably not needed*/ ),
    Options( {"/a", "/q", "/c dir && echo hello && ping localhost"} ),
    ReadFunction( Function( {this}, Write( this << read ) ) )
(Both of the above are set up to read from cmd.exe, as it runs, and write the answers to the JMP log. Your original example with readfunction("text") is the simpler, less flexible way that gathers all the output and presents it at the end.)
pmroz
You can also just write all of the commands to one CMD file and execute it.
C:\!N
cd ^path1^\!N
mkdir testing\!N
cd testing\!N
pause\!N
Niros
Solution:
cd ^path1^\!N
mkdir testing\!N
cd testing\!N
pause\!N
David_Burnham
For what it's worth, using RunProgram is tricky ... I suspect most of us have to try many ridiculous ideas before we get it to work :)
-Dave
pmroz
I had to add hard returns to the .cmd file generated by JSL using "\!N".
