How do I resolve the "Subscript Range in access or evaluation"
I get error
"Subscript Range in access or evaluation of 'openDTs[ /*###*/1]' , openDTs[/*###*/1]"
but it works on some folder and I don't get the error...Below is my JSL
JSL "
dir = Set Default Directory("path");
Print(dir);
files = Files In Directory("path");
For(i = 1, i <= N Items(files), i++,
	If(Ends With(files[i], ".txt"),
		Open(
			files[i],
			Import Settings(
				End Of Line(CRLF, CR, LF),
				End Of Field(Comma),
				Strip Quotes(0),
				Use Apostrophe as Quotation Mark(0),
				Scan Whole File(1),
				Labels(0),
				Column Names Start(1),
				Data Starts(1),
				Lines To Read(All),
				Year Rule("10-90")
openDTs = List();
For(i = 1, i <= N Table(), i++,
	Insert Into(openDTs, Data Table(i))
For(i = 1, i <= N Items(openDTs), i++,
	openDTs[i] << New Column("Location", Character, Nominal, Set Each Value(dir));
	openDTs[i] << New Column("FileName",
		Character,
		Nominal,
		Set Each Value(openDTs[i] << Get path)
openDTs1 = openDTs[1];
Remove From(openDTs, 1);
Joined_new = openDTs1 << concatenate(openDTs, output table name("Joined_new"));
Re: How do I resolve the "Subscript Range in access or evaluation"
Could it be that some of your folders have no files which could be turned into data table and openDTs is empty list?
Edit:
You can add check and stop if no tables have been opened. I made slight modifications to your script but the idea should still be the same with the exception of final checks after the the loop (requires JMP16+) and it assumes you want to only use tables which are found from your directory
dts = {};
For Each({filepath}, files,
	If(Ends With(filepath, ".txt"),
		dt = Open(
			filepath,
			Import Settings(
				Strip Quotes(0),
				Scan Whole File(1),
				Labels(0),
				Data Starts(1),
				Lines To Read(All),
				Year Rule("10-90")
		dt << New Column("Location", Character, Nominal, Set Each Value(dir));
		dt << New Column("FileName", Character, Nominal, Set Each Value(dt << Get path));
		Insert Into(dts, dt);
If(N Items(dts) == 0,
	stop(); // stop here as no tables have been created
, N Items(dts) == 1,
	dt_final = dts[1]; // only one table
, // else - more than one table
	dt_first = Remove From(dts, 1)[1]; // Remove From returns a list -> take first index
	dt_final = openDTs1 << concatenate(dts, output table name("Joined_new"));
Edit 2: Fixed Open(files[i] to Open(filepath
Edit 3: Fixed openDTS1 to dt_first
Edit:
dts = {};
		dt = Open(
			filepath,
			Import Settings(
				Strip Quotes(0),
				Scan Whole File(1),
				Labels(0),
				Data Starts(1),
				Lines To Read(All),
				Year Rule("10-90")
Don't I need to define "i"..I get Name unresolved for i...
Type on my code, replace files[i] with
filepath
Also the OpenDTs1 called here should be "dts"?
It should be
dt_first
