Melissa
How do I reference to a column by column number in jsl when column number is a variable?
I'm having trouble subsetting columns.  In the code below, I'm looking to create multiple new data tables (and perform some analyses with them- though I deleted that part of the script) from my current table. My current table is formatted with one "X" column (column 1) and several "Y" columns (columns 2 through ncols(dt). I'm having an issue where the columns() function does not recognize icol as a variable representing a number (I assume it's looking for a column named icol). Is there a fix for this?
dt=current data table();
For( icol = 2, icol <= ncols(dt) , icol++,
	dt << Subset( All rows, columns( 1, icol  ))
ron_horne
Re: How do I reference to a column by column number in jsl when column number is a variable?
Hi @Melissa
try this method,
icol = dt << Get Column Names();
For( i = 2, i <= N Items( icol ), i++,
	dt1 = dt << subset( all rows, columns( 1, icol[i] ),
		output table( "subset - " || Char( icol[i] ) ),
let us know if it works for you.
ron
ron_horne
Hi @Melissa
try this method,
ron
Melissa
Thanks! that's exactly what I was looking for.
